Thanks I now see the plug , why has it a rear dip stick ?It’s the 10mm plug, between the engine bolts....undo it, and you have a passable imitation of the Exxon Valdez
John
Thanks.These engines - like many others - fit onto a variety of machines. Therefore you may find two dipsticks which should sort all applications.
Indeed, sometimes the oil filler holes are much higher than the required oil level, just to confuse the issue more!
John![]()
10/40 w put in, thanksI agree, access is often tricky and you are often left with oil residue smeared over the machine by removing the drain plug.
I have a vacuum pump that works from my compressor and I tilt the machine so oil drains to the lowest point of the engine so I can get as much of the old oil out as possible.
You may find a 10mm combination spanner easier to use than a socket - use either a straight 30 grade lube or a 10/40 multigrade.
John
