I'm a confident DIYer & in the process of updating the bathroom & therefore changing all fitments. They have all been removed. However during the process of removing the bath I went through the following process.
1. Main house stopcock turned off
2. Both red stopcocks on the hot water tank turned off
3. Ground floor(kitchen) hot & cold taps opened.
All flow through all taps stopped with the exception of the bath cold tap which had a small constant flow of water. This flow was not under pressure.
Bath has been removed OK and taps replaced back onto pipes as a temp measure. My question is where is this water coming from?. When I come to refit the taps I would prefer to have NO water running out of this cold pipe for obvious reasons.
