I live in a stone cottage where much of the pipework is inaccessible (even the Water Board can't find where the water comes in!) and there's no internal mains stopcock. The bathroom radiator, which is on the ground floor, remains luke warm (evenly over its whole surface) while all other radiators are hot. It Bleeds OK, and the inlet valve is hot, so the radiator must be blocked within. However, the heating system is a "closed"/"sealed?" system and the "expansion tank" is a sealed plastic container with a pressure valve attached.
How can I clean out the system (and with what) when there is nowhere I can feed in a cleaning fluid? Then again, there are no thermostatic valves on the radiators, so how can I re-balance the system when PlumCenter tell me that mobile radiator thermometers are a thing of the past?
