Hello,
Just moved to a new flat and sadly found a problem with the boiler which I hadn't noticed on initial inspection.
The system is an electric PulsaCoil 2000 hot water boiler - a large cuboid steel box, which I assume contains a hot water tank and immersion heater etc. Haven't taken the front off yet, but might investigate.
On a shelf above is a small plastic tank, with pipes running into the boiler - I assume a cold water feed tank to keep a head of water for the boiler.
However I have noticed that this cold water tank was boiling hot, and has developed a leak from one of the pipe connections. I assume the heat has expanded the tank or the connections and allowed the leak.
Any suggestions as to what might be causing the header tank to be hot?
One possibility could be that I have unwittingly used the 'boost' heater for the last 36 hours non-stop. There are two wall mounted switches for the heaters, marked 'Heater 1' and 'Heater 2', so I switched heater 1 on, but subsequently noticed it also said 'Boost'. Perhaps I should be using the other switch?
However, I would expect the system to have some kind of cut-out and not vent hot water to the header tank under any circumstances.
Your thoughts are much appreciated!
J
J
