Cold water into garage for washing machine
26 Dec 2009
Lancashire
Just moved into a bungalow and I want to put the washing machine into the garage. Drain is already there but no water.
Am I right in thinking I can cut into the mains in the kitchen and run push fit pipe through the loft and come down into the garage?
The pipes are 15mm in the kitchen, will I have to increase the size of the pipe I am running or do anything special to ensure the pressure is ok?
Thanks for any help Adam.
As long as the mains pressure and flow is ok then there should be no issues, you may want to consider insulation on the pipe run.
