Cold water tank draining and lid
27 Oct 2009
Hi All. We have a cold water tank in the loft (there's a littel expansion tank there too) and the cover/jacket had fallen in. There was never any rigid cover on it or anything. So now we've removed the cover and thrown that out, but there are bits of foam in the tank and the water is murky.
I am planning to drain the tank and clean it and put a proper cover on, but i cannot find a stopcock to prevent the tank filling up again. Ive found two, which are for the bathroom cold taps and to fill the hot water tank. Is the one that stops the tank filling up in the loft? Ive had a good look and cant find anything.
Rich
you want the main supply stopcock. Commonly found near the kitchen sink, or in the pavement, or buried just inside the boundary next to where the front gate used to be when the house was built.
Find it. You will need it when you have a burst or leak.
BTW bale out the rubbish from the tank e.g. with a sieve. If you try to drain it through the pipes they will get blocked
For today you can tie up the float to prevent the valve refilling the tank.
We have a stopcock in the cupboard under the stairs, would that shut off the water to the cold water tank? Im not sure of the direction of the pipes or whether it comes to the stopcock first or theres a separate feed to the cold water tank.
Once drained, is there any special product to clean the tank with, or a particular method?
I'm not familiar with your house so I don't know where your stopcock is.
Try it and see.
After cleaning your tank you can wipe it round with bleach to kill any remaining bacteria or fungus.
