I had the ball valve replaced on my cold water tank in the loft, gravity fed system, and now it is very noisy refilling after a shower, it’s like a loud hissing noise which it never made before. Any suggestions as to what the cause is or how to resolve thanks
If there's an isolator on the feed pipe, make sure it's a full bore one, and is fully open.
You can also adjust the angle of the white spout which could help.
John
Could be as above from @Burnerman, although it doesn’t have to be full bore, but fully open. Could be a faulty valve, hard to tell just from what you’ve told us.
