cold water trickling in shower
27 Jan 2009
Lancashire
Hi, I've removed a bathroom suite in the family bathroom. To do this I had to drain the cold water storage cistern.
I've since turned the water back on and now the cold water to the shower (in a different bathroom) is trickling causing red hot water to come through the mixer shower. It's a gravity mixer without electrical supply or pump.
Thanks in advance for your help.
28 Oct 2005
Daventry
Sounds to me like you've got an airlock - are you having problems with any other outlets fed by the CWSC?
28 Oct 2005
Daventry
Hmmm...is the shower on a seperate feed?
If not, there is also the possibility of a blocked filter on the shower - if refilling the CWSC stirred up a bit of muck in the bottom it may well have gone down the pipes and clogged the inlet filter.
27 Jan 2009
Lancashire
I'm certain it's an airlock but how do i get rid of it? I've had an airlock on the bath taps before and cured that by covering the outlet and turning the hot and cold taps on and forcing the hot water up the cold but I can't do that with the shower?
S
swidders
have you tried?
28 Oct 2005
Daventry
Well if you're certain it's an airlock (have you checked the inlet filter??) then there are ways around not being able to use that trick on your shower.
You could try pressurising the shower through the hose. Might work, might not. I've never done it and you do it at your own risk and that of your shower.
Did you put a valve on the cold feed down from the CWSC to the taps/showers when you drained it down? If you did (would have been a good idea if you didn't) then close that, find a way of connecting the mains to the low pressure circuit and pressurise it, then turn the shower on (might be worth checking your shower's ok to be run on mains pressure first),
20 May 2006
Berkshire
take the shower head off
27 Jan 2009
Lancashire
***PROBLEM FIXED***
I attached the outside hose to the outlet of the shower, opened the cold on the shower and forced the airlock back into the CWSC via the force of the water from the hose.
Thanks for all your help. :p
