Hope someone can help.
I’ve just fitted three new column rads onto an existing system replacing some old rads. I haven’t been able to identify flow and return pipes because everything is boxed in and plastered over. Old rads didn’t hold any clues, no TRVs fitted. Long story short, two of the three are the wrong way around... lucky I’m not a gambler!
Obvious option is to alter pipe work BUT looking at the rads there is no obvious difference between the front and back, they appear symmetrical in every way. Is there any reason I can’t just turn the rads around so the “front” is against the wall and the “back” is facing outwards. That way the inlet will meet the flow pipe rather than the return?
Cheers!
Cheers!
