Combi-Boiler, hot water is cold and no bar pressure
3 Jun 2004
Hello all,
I have a Megaflo combi-boiler which seems to be experiencing some issues! The bar pressure has reduced to zero and the pump seems to be making more noise than usual. I have tried the method of getting the air back into the system to increase the bar pressure, but this doesnt seem to be working.
Another thing i will be trying is to clean the strainer which apparently could make "the hot water go cold" according to the user manual!
If anyone could suggest anything to me about things to try, maybe i havent even done the above properly (following the manual again!). I dont have an amazing understanding of central heating/plumbing, but am an engineer in trade so should be able to bodge it!
Many thanks in advance (if you need more info to provide a valid answer please just ask!)
I am a confused ol hector
do you have a combi or a megaflow as one is a totally different thing from the other
Combi = instantaneous water heater with a diverter valve to provide central heating.
Megaaflow= Brand name for the ebst selling unvented hot water cylinder on the british market, stores hot water but heated either directly with immersion heaters or indirectly by external heat source via super efficient coil
