- Joined
- 29 Jan 2006
- Messages
- 2
- Reaction score
- 0
- Country
Hello,
I hope you can help deceifer my post as I'm a little confused. I've just taken possession of a brand new house and I'm not quite sure how things work. I'll describe below.
There's a gas boiler in the kitchen. I think this supplies the heating only.
There's an emersion heater in the middle-floor airing cupboard. Also in the cupboard is a little red round tank about 1' round and high.
In almost all houses that I've been in before, if you turn the hot tap on then the boiler fires up and hot water comes out. I'm read some of the blurb on the net which describes the different types of setups, eg. 'system' configuration.
Here's where I'm getting confused. I have the emersion switched off on the wall, and with the central heating on for a few hours, if I then touch the pipe on the emersion heater then there's hot water in there.
There's a panel in the airing cupboard which controls 'hot-water' and 'central-heating' in a similar way to what I've seen before.
Should hot water be being supplied by the gas boiler? Is the gas boiler inadvertantly heating the water in the immersion heater?
Bit worried if this is going to be expensive if I need to have an emersion on for hours to get hot water.
So confused.
So confused.
