Hi all,
Just after a bit of advice. I'm not sure if this is normal or if the boiler has always been this way, I've only noticed as I've been preparing to fit smart TRVs to some of the radiators in the house and need the boiler to be set to constant to be able to heat rooms on demand.
I have a Logic code combi 26 that's about 12 years old. When CH is set to constant, the burner fires up when the radiator calls for heat and goes off when not required. However, the pump (I think) never stops making a noise as if it's circulating constantly. It doesn't go off after a few minutes and will run all day unless the heating is set to off or timed. This also happens if no radiators are on and the CH is set to constant - the burner stops off after a minute or two but the pump (?) never goes off.
Is this normal?
Is this normal?
