having had a combi boiler, we discovered it is unable to supply hot water at peak times due to low mains pressure .The installer is recommending adding a tank system with pump. what options are their. Is it possible to use a tank plus pump to supply water to the boiler at sufficient pressure, and then still work as 'hot water on demand'. Is this likely to cost hundreds or thousands of pounds?
