    Dismiss Notice
Combi boiler shower going cold
Discussion in 'Plumbing and Central Heating' started by Johnking, 13 Nov 2020.
  1. Johnking
    Johnking
    7 Sep 2006
    183
    Thanks Received:
    London
    Country:
    The flow rate through my shower is a bit low, resulting in the boiler cutting out from time to time. The shower doesn't have a restrictor, but I wondered about trying to find a high flow shower head. Do they exist, will it work?
    (Boiler had diverter replaced, taps produce hot water fine, it's just the shower).
  2. Sponsored Links
  3. oilhead
    oilhead
    29 Nov 2009
    2,142
    Thanks Received:
    510
    Shropshire
    Country:
    Has it always been like that? Take off the shower head and see if it still stutters. Try descaling the head, otherwise. get a bigger head. The more holes, the more water will pass.
  4. Johnking
    Johnking
    7 Sep 2006
    183
    Thanks Received:
    London
    Country:
    I've modified the head by breaking of the little rubber nipples that create each individual jet. Much more water flows and it seems better, but the jets have no oomph. Guess I need something between what I had and what I broke.
  5. gas112
    gas112
    27 Oct 2009
    22,508
    Thanks Received:
    8,040
    Country:
    what boiler ?
    • Like Like x 1
  6. CBW
    CBW
    26 Sep 2019
    9,109
    Thanks Received:
    2,444
    North
    Country:
    Check the shower hose for a restriction/collapsed inside
  7. terryplumb
    terryplumb
    8 May 2017
    6,174
    Thanks Received:
    1,279
    Country:
    Check the filters in the showers inlets.
  8. Sponsored Links
  9. Johnking
    Johnking
    7 Sep 2006
    183
    Thanks Received:
    London
    Country:
    It's an old Vailant Turbomax.
  10. Johnking
    Johnking
    7 Sep 2006
    183
    Thanks Received:
    London
    Country:
    Do you mean remove the Grohe bar thermostat mixer and look at the H&C inlets? We do have very hard water.
  11. Johnking
    Johnking
    7 Sep 2006
    183
    Thanks Received:
    London
    Country:
    No, not that, and i removed the restrictor before I fitted it.
  12. terryplumb
    terryplumb
    8 May 2017
    6,174
    Thanks Received:
    1,279
    Country:
    Yes ,that's how to do it. The filters are within the bar mixers inlet ports.
  13. Take the shower head off..What is it like with hose alone?Sorry.been said
  14. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
