combi boiler temp query
17 May 2009
West Glamorgan
been doin some searching for some info this evening as the mrs has been going bonkers as the house has been really cold as of late, for what temp i should have my valiant eco tech pro combi boiler at.
i have read that if i want my bills low i should have it set around 50-55, but if i this wasnt hot enough i could go upto 80.
i havw set mine to 65 and goin to give it a try for a couple of days. is this correct?
also my query is, along side what i read about the rad temp is the water temp should be set to a relavent temp? mine is set to 55
thanks kris
i have 9 rads if this info is relevent to setting temp?
When you think of the heat loss of your system by the time the water gets to your last rad on circuit you might drop 10 degrees 45 degrees is barely warm just about comfortable bath temp.
I suppose you might argue the higher the better as the rads will radiate more heat and warm the room quicker but I imagine there is cut off point where this no longer becomes the most efficent idea
Try experimenting with your settings until you find the optimum setting where your house is evenly warm and your boiler isn't trying to fire constantly to make the temp back up
