combi boiler
28 Jun 2006
am entitled to a knew combi boiler from the council for the house (lucky me).
what i wanted to know is if i say yes how will it be powered? do they have to install a seperate circuit from the CU or is it just a matter of spurring off the ring socket supply?
worried about my newly decorated rooms!
cheers
they will likely spur off the nearest ring final and fit a 13a fuse (though it should be 3 amps - check this :wink: )
It will be spurred from the nearest convenient point on the (probably) kitchen circuit.
But don't worry about the decorations, the probability of them not using surface wiring is about 0.00000000000000000000000000000000000000000000000000000000000000000000000000000000000000000001
