Thanks muggles - So potentially if the house has been empty for a few days, I would have to run off 170lt of cold water before seeing hot appear out of the taps? Or is the feed off from the tank near the hot fill feed?
It seems a good system for a house that has a lot people living in it, to keep the cylinder always topped up with hot water? But not so good for occasional hot water usage?
No, if the cylinder is hot then you will have hot water, if the cylinder is cold you won't. So if you're away for a few days you need to set the timer (which I think *may* have a holiday mode) to be off for a few days, and then come back on in time for when you're due to return. It doesn't take very long to heat the cylinder, and I doubt there would be many situations where you got into a house and immediately had to use a hot tap, so provided you switch it on when you return it should be fine by the time you've settled yourself back in.
