combi install
2 Feb 2009
Durham
Hello.
Can you still buy single rad valves that have both flow and returns on one side of the radiator? Have put a price in to install a combi and now i am a bit concerned that if these existing valves are going to leak under pressure. I wanted to repipe to both sides and put trv's on but the customer doesnt want the mess of going into stud walls. Any ideas please?
Can you not just make them aware that it could be a problem, offer it as an extra but tell them if they leak due to the increased pressure they are not covered
you can still get them if you hunt around, google it. About £28 last time I found some.
I googled it and got 2 twin rads for an alfa romeo. fantastic lol. customer your rads are cold but **** off a stick. Seriously though i dont think the install is worth the hassle. It needs new pipework for me to be worry free. thanx micky
The dual valves (trade name Maxitwin) will be fine with increased pressure if they are the yorkshire/imi ones. If i remember correctly they were rated at 3 bar.
Only problem with leaks was on the lockshield, side from screw but you can tighten the cap down with grips. It contains a fibre washer and will seal fine.
Talk them into changing if possible because these valves can be a pain with the insert tube blocking or not connected if someone has had the rad off.
You may still get them from some merchant who has them lying around but they discontinued them last year according to Yorkshire web site
http://www.pegleryorkshire.co.uk/EN/ProductDetails/Main?Id=5ee242db-1407-4bc9-9747-41d56bcca443&d=1
Danfoss used to do a TRV version. May still do them?
