hello, would just like some advice on installing a new combi. The problem i have is the water pressure is only 2 bar and the flow rate at kitchen sink is 8lts/m. i have checked the flow rate at the main stop cock outside and is only 11lts/m. so i dont see the point in running a new water main.
At the moment it is a bungalow with tanks in loft but the owner is converting the loft into bedroom with en-suite, because of this i will lose the height for a tank to feed the en-suite shower. My plan was to put a break tank at low level in the loft feeding a wilo whole house pump to run the combi and colds off. A friend has suggested to me a cheaper way by installing a 300ltr vessel in loft connected to the mains which will act as a pressurised store. would like to know if anyone has tried this and is it likely to increase the flow rate by much? As usual the owner would like the cheapest but best option so want to get it right first time.
thank you.
thank you.
