- Joined
- 22 Dec 2015
- Messages
- 45
- Reaction score
- 4
- Country
Hi to all.
I have a Baxi 105e instant combi boiler that has served us well since 2004. In that time it has of course had interval services and has been pretty much bullet proof. There is also a proper water softener in the house that feeds everything, except of course, the cold feed over the kitchen sink. The plate heat exchanger was replaced about three years ago.
Then a couple of weeks ago the shower was running cold all the time. The gauge on the front was in its usual place at 1.5 and the hot water was running fine from the taps.
I called Brit Gas for a fix and the guy changed the DHW diaphragm and the temp sensor and said the boiler was in good working order.
The following morning the shower ran hot at first but then ran cold for about ten seconds, then went back to hot. So, I had a recall from Brit Gas who again said the boiler was fine and that I should look at buying a new bar mixer as he thought the problem was with that.
I've now changed the bar mixer for one of these https://www.amazon.co.uk/gp/product/B07XNWDFV7/ref=ppx_yo_dt_b_asin_title_o00_s00?ie=UTF8&psc=1
and I thought that there were too many 90 degree bends in the feed to it so I've re routed the pipework taking out most of the 90s. This has made a good improvement to the problem. The shower does go cold but only for a couple of seconds.
I've run the shower whilst looking at what the boiler lights display and the shower goes cold more or less when the boiler gets to its top temp and the burner cuts. Then, it re lights and the hot water returns. The other hot taps in the house run fine and don't go cold at all.
Is this a common problem? Why would it run well for all those years, then start playing up? The engineers both said the boiler was ok, But is it?
Sorry for a long post but I'm at a loss now on exactly what to do next.
Thanks. Steve
Thanks. Steve
