I've bought a commercial premises for my workshop that's needing some re-wiring, I'm just looking for thoughts on the best approach.
The unit is in 2 parts (front/back) - power comes off the street at the front where there's a CU for the front, then there's a another mini 63A CU that runs to the back (which has another 8 port CU connected to it). It's the back unit in question, as the workshop will be there and require at least 4x 30A machines, plus a number of other small draw machines.
So obviously the 63A breaker will need up-rated or by-passed. Just now the back unit has around 30x 600mm fluorescent lighting panels across 4 spurs (10, 10, 5 & 5 lights on each). The spark is pushing for me to replace the fluorescents with LED as they could all be put on 1 spur, but that's probably going to be £800+. I know it's all about the load, but would it be a better option/possibility to combine any of the lighting spurs - or install a larger CU? Or both?
