comi boiler
31 Dec 2013
Hi, when I turn my combi boiler to hot water only the rads heat up also. can you help.
[quotTe="Dan_Robinson";p="2995520"]Diverter valve.[/quote]
Thanks for your un-helpful remarks, as a universal idiot you should know there is not a diverter valve on a firebird combi boiler
Maybe it is you that is the" universal idiot" where in your post did you mention that you had a Firebird combi ?
This made me smile :D
if there is no diverter then it most likely has a bithermal heatexchanger (forgive me if im wrong, not familiar with the appliance). These work with a coil inside the primary circuit and reverse the circulation back through the boiler. It will most likely have a valve of some description to stop the issue you are getting.
Sorry i cant be anymore help...
NB
The problem with the Internet. ... harder to hide your stupidity when what you write gets quoted for posterity.
OP.
You are an idiot. Good bye :D
