Comip setting up
19 Mar 2014
Bournemouth
Hello all
I've just installed my prem 24 with comm2400 for texting.
All ok.
Now I gave the app for the iPhone so have invested in a comip module
How do you get it to work
Thanks in advance
From Texes documentation:
"The mobile apps are compatible with Premier Elite control panels V1.00 and above and Premier 48/88/168 control panels V8.14 and above."
No mention of the 24. My understanding was that 24 wasn't compatible with the COM-IP. This was a while back when I invested in a 48 for testing.
I agree with the above, suggest you confirm one way or another with Texecom tomorrow.
All the Elite range, Premier 48 V8.14 (note previous versions can be flash upgraded) and above, some of the international panels but would have to check the version numbers.
The old premier 24 which finished at version 8.33, can utilise a com-ip module with wintex, or or using the online keypad program from a windows pc, but can not be used with the current App.
This is due to the protocol being used on the app is not supported on the old 24.
If you have an panel compatible with the app, you just need to put the details into the app, ip address etc
