unlike my normal boilers (WB) the raven heat needs the gas pressures 'adjusting' the low is 2mbar and is adjusted on the honet well valve by a brass nut the 'high' (10mbar) is adjusted with the plastic nut on the same 'spindle
the question is why the Flip wont the high adjust, when i turn the plastic nut it rises to 8 then drops again the pressure changes just by touching the nut never mind turning the thing ... its driving me nuts.. i must be missing something simple
( i have tried adjusting it with one of the solinoid wires disconected as per the MI and it makes zero difference) frustrating the gas rate is just about ok but what to have this pressure nailed..
cheers..
cheers..
