Our firm often gets called out to lighting issues after a general relamp, i recall at least twice where evacuation and fire brigade have been involved.
It has even happened a few times on my work, where i have replaced a tube and starter and within 24 hours the magnetic choke has overheated, given off a burning smell and eventually tripped the circuit.
As well as sometimes fitting lamps and the lamp blowing instantly then on inspection the choke had been burnt out, likely ages before but still connected.
I now open the fitting and visually check the condition now on switch start units before relamping.
Most of our clients no longer want the old technology, so use a failed light to upgrade to led, as they know its unlikely they will get the whole premises done in one hit.
You could run off to the wholesalers return with a tube and starter, only to find the fitting dont work.
Only last week fitted 2 brand new 6ft tubes and 2 decent starters, to save a return visit, and we then report back to get upgrade authorization, only to be recalled next day anyway, to find both flashing independently, and the ends so black ended, they looked years old, job was 2 hours away, and I got there just 2 hours before they closed, so no time to upgrade to Led.
Put a further 2 tubes and starters in till the estimate approved
I disagree the customer should have been left with no light, a temporary at least should be put up.
I appreciate Sunrays dilemna, but If something went wrong, even as simple as tripping an Rcd, he could have a lot of explaining and although likely more competant than the Bufoon that attended, at least they would hopefully have some Liability insurance.
I am surprised they even let you in the premises carrying a 4 foot tube.
