I am about to start re-fitting my ensuite and I'm looking to replace the existing toilet with a back to wall pan and a concealed cistern.
Due to the layout of the room, I would like to place the concealed cistern to the side of the pan - about 3ft away - see photo below! (This will tuck behind a false wall next to my shower). There is the room to position the cistern at any height (to compensate for any loss of pressure due to the location). I intend using a pneumatic flush button.
A few Q's regarding this if I may...
1). Will this set-up work...? Or will I have 'flush' problems?
2). Are there any particular makes / models that would be best suited to this application? (Ideally a slim model - 150mm max depth, but would prefer 120mm or less for access reasons).
3). Will there be any issues with the flush pipe...? Are they standard sizes so I can make up the run (inc 2 x right angles) with supplies from my local plumbers merchant?
4). Any gotchas I should look out for...?
Thanks in advance for your help - it's really appreciated!
Cheers,
Noswar
Cheers,
Noswar
