Concealed Hinges
27 Apr 2004
I have already done a search on the use of the above and have found other postings on this.
However, I am looking for guidance on the appropriate dimensions when fixing the hinges to the doors (the cabinets are pre-drilled).
There was a link to some info, but I couldn't get my head round the desription there - anyone have simple instructions on how to fit these?
I think the hinges are sometimes called Blum hinges?
The edge of the hole you bore in the door should be between 3 and 6mm from the edge of the door. For a 35mm diameter hinge we usually mark the centre of the hole 22mm in from the edge.
Just spotted that your cabinet is pre-drilled, the easiest way for you may be to fit the hinge plates to the cabinet, then get someone to hold the door against the edge of the cabinet in the open position so you can mark on the door how far up and down your hinges should be.
