Hi.
I am fitting a concealed shower vale, but need to know what fitting I should get.
Both of the hot and cold inlets have a white plastic fitting inside that pushes in and out on a spring. There is a retaining clip holding this part in place.
The problem is that with this fitted I cannot get a seal with a fitting as the part is almost flush with the end.
If I take them out the shower doesn't work. It looks as if they should be pushed in further so I can then get a fitting on the thread with a good seal.
Any ideas.
Cheers.
Any ideas.
Cheers.
