- Joined
- 2 Oct 2016
- Messages
- 2
- Reaction score
- 0
- Country
I am looking to install a hanging shelving system from the ceiling of a leasehold flat. As shown in this image:
The ceiling to the flat is a painted concrete slab, which then forms the floor to the flat above. I therefore cannot bolt through the slab and install fixings in the flat above. But assuming this slab is 200-300mm thick I should have no problem fixing concrete anchors 100mm in to this.
I appreciate that there is an issue with the arrangement of leasehold in relation to fixing in to the structure of the building. But assuming I can negotiate this I wanted to understand if this would be possible in principle or if it is likely to cause a problem.
The shelving unit I want to install is built from ply, the top panel which I would fix to the ceiling measures 2400mm x 450mm. In theory I could install multiple concrete anchors in pairs down it's length. Many of the anchor products claim to hold 60kg from a single point, so in principle installing as many as 10 fixing points should help to distribute the weight and should be more than sufficient. I'm keen to know if you think this would be possible or is it too risky to rely on anchors to hold a system such as this?
