Having looked at the possibility of using sleepers for the retaining walls we want to build, we now are thinking about using concrete blocks, rendered and capped.
We have a main retaining wall approx 14.5m wide down near the house/patio that will be 4 blocks high with a brick capping and will have a set of steps built in up to a levelled lawn area. Then at the sides the walls will be 6m long to the back of the garden, where the rear wall will be 3 blocks high and 12m wide
As the garden is being levelled due to it's sloping nature upwards and away from the house, the soil removed from the rear will be dragged to the front where the main retaining wall must be built first to pile the excess soil behind.
So.... I'm told that: the sides and rear wall will only need to be single skinned, while the front wall, being the main one near the house, will need to be a double skin wall with ties as it's taller - 4 blocks high.
The point of this rambling diatribe about my landscaping nightmare is that I don't know what size blocks to use. 100mm, 140mm or the hollow block. Can anyone offer any advice please?
Then I want to install low-level lighting in the wall, which will no doubt add insult to injury as I strive manfully to achieve something resembling a garden! On the plus side we have a mini digger and driver arranged to level the garden.
Thanks in advance...
