hi there,
I am planning to do some works on my ground floor council flat. As part of this i plan to remove a wall separating the kitchen and living room. I commissioned a report from a local structural engineer to check whether this wall was non-structural (I believed it was) and his report confirmed this.
The wall in question is 60mm thick and constructed of some form of brick (the report stated clinker brick). Both floor and ceiling are concrete. The surrounding walls are all 190mm thick. The total width of the wall that will be removed (inc door) is 3.5m. The length of the unified kitchen/living would be approx 8m.
I applied for both planning permission and building control, as my initial plans included unifying two of the bedrooms. Permission was granted for both (the structural engineer's report was included in the submitted documentation).
I have now applied to the freeholder (the LB council housing assoc) regarding permission for this work, so that the lease can be amended to reflect the changes. Their surveyor inspected the property and stated that evidence will be required that the steel reinforcement in the ceiling concrete runs in the same direction as a the wall i propose to remove, rather than perpendicular to it. Alternatively he proposes a have a beam placed along the ceiling in the same location as the wall (I don't want this).
Though I'm not a structural engineer myself I am certain that the wall concerned is non-structural. My neighbours (who have not gone through this process) made the same alteration 3-4 years ago without impact to their flat or their neighbours above. My surveyor is adamant that the wall concerned is non-structural and placing a beam there would be of no structural value. He has suggested digging into the ceiling to determine the direction of the reinforcements.
Ok, enough preamble.
My question is this: Is digging into the concrete ceiling a common way to determine the direction of the steel reinforcement supports? (Presuming that documentary evidence about the construction is unavailable)
Is there a non-invasive way to determine the same information? Some sort of electrical device?
I am separately exploring other possible avenues such as obtaining the original engineering drawings (unlikely, it's 70's build) and getting the structural engineer and the surveyor to meet.
many thanks in advance
