Concrete curing membrane products
14 Apr 2017
Hi guys,
Anyone know where I can get a decent anti-evaporation/curing membrane to use once the concrete for my slab has been finished ? I won't be screeding, so I need a good strong finish on the slab, but for whatever reason I cannot find many curing membrane products out there. There is Ronacrete from screedgiant.co.uk but the delivery is a whooping £45 for a 5L litre product that only costs 14 quid!
Phone Hope / Breedon.
Though you want to power float it rather then spray a membrane on unless you have a scc. But even then giving it a mist with the hose does just as good.
I use larsen acraseal. Delivery will be a problem due to the nature of the chemicals being classed as hazardous by some couriers.
Is the concrete going to be powerfloated and left as the finished flooring? If not its really not necessary.
+1 you can use a wb sealer as well.
The ones you use for stone tiles work as well.
Thanks - do you know of any distributers on the mainland?
It's going to be bull floated, and then finished with a swimming pool trowel, and then the membrane sprayed.
Are you sure?
Sorry I'm in northern Ireland. They do have some mainland uk distributers but don't know any. Try ringing them, they have a depot in belfast and are very helpful.
The Larsen stuff is acrylic and id imagine a very similar make up to Thompsons water seal.
Do you intend to put a further sealing product on top for the long term?
