I've an idea to slot 8ft concrete slotted fence posts at ground level in the cavity of 600mm high concrete block double skin walls; once slotted in, I'll fill the whole cavity with concrete. I'll then fit 6ft high fence panels above the wall level, so 600mm off the ground.
I'm fairly sure this will create enough mass to overcome any lateral forces from the wind on the fence panels, but I'd like second opinion.
anyone ever done this? the wall is built from heavy concrete blocks
