Concrete foundations/ floor levelling
6 Apr 2009
London
Help! I want to build a large garden room around 6m x 3m. I already have an old concrete base which is uneven. Can anyone tell me the best way to build on this? Should I level the floor or put in some piles? If I screed a concrete leveling compound on top of the existing concrete will it not crack? Alternatively I have thought about laying concrete blocks and build on these as supports (providing they are all level)
Any help would be greatly appreciated
Many thanks
Dan
Personally, i use trench foundations whenever possible. That is not to say the base may not still be useful.
I would dig a trench foundation around the existing slab perimeter, lay concrete foundations then build blocks/bricks off the concrete up to dpc. If the existing slab is well below dpc then it could be used as a sub-floor or even hard core.
dpc should be set at 150mm above external soil level.
Use solid dense concrete blocks or class b engineering bricks below dpc.
