The opposite is true.The fact that there are planks on top of the rebar mesh, presumably to walk on or to roll barrows, gives away the fact that the concrete beneath has definitely gone off.
Stick to painting, decorating and gardening, pal.
It wasn't like pish, no, but not stiff enough to stand the weight of the barrow between mesh spacing - hence the planks.Or it was a stiff mix around the 0.45 water cement ratio as opposed to the runny mix some use to make things flow easier?
Thats definitely going to be structural reinforced concrete as opposed to a bit of mesh to control early shrinkage and cracking on a mass concrete floor slabView attachment 379117
You're all on the dole lads, the company's adopted the super-efficient "Noseall Chuck it in and run method".
Your lack of knowledge regards the building trade is staggering. Don't ever give up that paintbrush pal.You're not going to get any fresh concrete mix to hold up a plank with a wheelbarrow on top.
Ignore the clown Ivor, he thinks he knows better than SEs too.You'd probably be better off without the steel vs this method. It just breaks the concrete into two slabs so weakens it and will rust, expanding and cracking the concrete around it.
Not until you can find one that can find a difference between wet concrete being forced under mesh and wet concrete being placed under mesh, no.he thinks he knows better than SEs too.
Correct, I wouldn't call it cute though. Just ill informed. And I have been disregarding 'the clown Ivors' posts for a while now.Awww bless. Kind of cute watching someone utterly unable to admit to being wrong. As normal, out come the playground insults.
Clown Ivor is just overly keen is all, no need for playground insults.Ignore the clown Ivor, he thinks he knows better than SEs too.
