Concrete on concrete
27 Jul 2010
Wiltshire
Hello,
Ive dug out loose material from the fireplace in my house and filled with a few inches of concrete. Due to the depth I need to do this in two stages, I have done one layer and need to fill the final few inches to get it level. I understand concrete wont stick to concrete, what can I do. The strength and stability of the concrete is not an issue as I am only filling it to get it level to put a hearth on it.
Any ideas.
Laying a few inches of concrete onto already existing concrete will pose no issues, If the concrete underneath is still green you could scutch the top layer off to give you a bond,however, its not structural. If your wanting a super smooth level then you could always pour in self levelling grout.
Regards Otto
Is it going to be used as a fireplace again? If so, self levelling compound is right out, and the thermal issues might cause problems with a thin layer of straight concrete. Be interesting to see what the majority viewpoint on this is.
Thanks for all your help, I have two fireplaces, this one will not have any heat as its just for show so I have levelled the concrete so that I can level the hearth. The other will have an open fire, there is already concrete in there will a thick hearth be good enough to stop heat transferring to the concrete below or should I take other precautions?
I'm sure there won't be any problems with what you propose - concrete will stick to concrete no trouble if the surfaces are roughened (keyed) - if you want to help things even more a thin brushed layer of PVA adhesive won't do any harm either.
John :)
Concrete will stick to concrete, but it depends on the depths we are talking about. If you intend to pour less than 2 inch it may not bond that well and shear away after time.
If it is only a few mm out, you could well get your level when you bed your hearth in.
