    Dismiss Notice
Concrete Slab in front of Bay and Door
Discussion in 'In the Garden' started by myminimonster, 7 May 2014.
  1. myminimonster
    myminimonster
    7 May 2014
    3
    Thanks Received:
    Leicestershire
    Country:
    Hi everyone,
    Im after a bit of advice regarding some concrete slabs that sit at the front of the house.
    I am about to sort out the front of the house but there are two unsightly concrete slabs that are in front of the bay window and front door. The drive is already covered in stones but only upto these slabs.
    The one in front of the bay is in a worse state than the door on.
    I was wondering if its ok to to crack these up and remove them both and if so do you know if they are likely to be deep or just a foot or so deep.
    Once they are removed what measures should i take before covering the area with driveway stone. Do i need to seal/protect the brickwork on the bay where i have taken the slab out?
    Thanks in advance and hope its clear what i mean with the pictures.The house is from the 1930s.
    thanks in advance
    Adrian
    [​IMG]
    [​IMG]
  2. Sponsored Links
  3. scbk
    scbk
    22 Dec 2012
    916
    Thanks Received:
    172
    Ross-shire
    Country:
    I would keep the door one if you can, much better to have a bit of concrete than loose stone, should mean less dirt trampled in the house
  4. drpepe
    drpepe
    4 Feb 2014
    194
    Thanks Received:
    10
    Bristol
    Country:
    have you tried digging next to them to check depth? that would be the first thing i'd do...
  5. geraldthehamster
    geraldthehamster
    7 Feb 2010
    2,973
    Thanks Received:
    320
    Country:
    I agree, or replace it with a nice slab of sandstone.
    Cheers
    Richard
  6. myminimonster
    myminimonster
    7 May 2014
    3
    Thanks Received:
    Leicestershire
    Country:
    Thanks for replies. I have not cheeked the depth yet, I was just enquiring in case someone knew what they were off the top of their head or had dealings with such constructions of houses of this age.
    Good idea about the door slab. We already had ideas to replace it with a new step as there is a 6" square slab/ step between the one in the picture and upto the front door under an archway .
    Was thinking of using some bullnose blocks in semi circle to create gradual steps to the door.
    The door base is approx 10" higher than the slab seen in the pic
    Adrian
  7. arkie
    arkie
    4 Feb 2010
    73
    Thanks Received:
    5
    Country:
    The path could just be covered in fresh gravel, gravel on concrete can be like marbles but your unlikely to walk on it and nice slabs could be used to build up on top of the step.
  8. DIYnot Local
    3 Sep 2019
    Country:
  9. Sponsored Links
Loading...
Share This Page
