Hi all, I am brand new to DIYnot (thankfully found this wonderful site). I'm building fairly remotely in Mozambique and have a question about applying a screed to my current slab. The slab is 150mm thick, steel reinforced and been in place for 3 months as I build the house on top. Am building on a sand dune so the dpc membrane is under the slab. I need to put a screed layer on top which will then be acid stained and sealed. Size is 50 sq/m.
The question is what will be the easiest way to bond the thinnest screed to the slab. This is a problem of logistics as getting materials to where I am is tricky and expensive. I have a couple 20l tins of bonding liquid which I was considering using to bond the screed. Or is it better to use a slurry mix just prior to throwing the screed? I'd prefer to keep the bonding liquid if i could but will use it if it's a safer bet for securing the screed. How thick/thin can I go here?
Any thoughts greatly appreciated.
