condensate drain flexiable pipe
15 Oct 2009
does the condensate drain have to be rigid plastic or can you use flexiable pipe that is good and strong
The problem that I can see with using a flexible pipe is that you may not be able to ensure a continuous fall along the length of pipe and so end up with an air lock.
In principal, provided that it is made of a suitable material and is the required size for the location of the pipe, then I cannot see that you cannot use it but it may give you more headaches than you have cured... whats wrong with using rigid pipe?
there are sevral bends under floor boards may be i will fit a pump to the pipe
Why, what height is boiler from floor. you will have a drop on it for most off the way even bit of horizontal is ok , Water will get out without backing up into the boiler.
There is no problem using suitable flexible pipe for condensate as long as there is no risk of leaking or freezing.
if you need to fit flexi a good idea is a washing machine waste extention hose, very flexible and has rubber ends to properly connect something to it
