Hello-my query is about the frequency of pumping and noise generated. I don't think it's been covered on other threads... Several weeks ago the installer a local heating engineer serviced the Worcester Bosch condenser boiler in cupboard on first floor and found a kink in the condensate pump pipe feed going up to the stack. This was after I commented about the worsening noise when the pump became active. The noise made by the pumping has now changed but it is much more regular, about 2 or three times every 90 minutes and doesn't seem to co-ordinate with drawing of hot water. Before this it pumped perhaps three times a day, and not for long. Central Heating is of course at present switched off. The plumber does not answer phone calls or text messages particulary well and I suppose he's busy and doesn't need my custom now - since installation I have always wondered if the condensate pump was configured correctly. It is screwed to the side stud wall - no sound deadening and I appreciate this will contribute - I've seen a thread referring to a side shelf and foam so will think about this too. But I suppose its the frequency of pumping that is concerning me in the main.The boiler is a Worcester Bosch Greenstar Ri and the Pump brand is Pro F & B. This pumping frequency has been going on for many weeksbut did not start immediately after the feed pipe kink was resolved.Installation of system was October 2017.Boiler serviced every year by installer but I do not think the Condensate Pump has ever been inspected inside. If he isn't interested I assume I could get another engineer on board and the 10 year boiler warranty would still be good?
