Condensate
26 Apr 2007
Bristol
A question regarding the regulations concerning Flues and Condensate disposal on a Combi Boiler system.
I understand that it is permissible to dispose of the condensate into a Rainwater System that is part of a Foul Water system but NOT into a rainwater system that is NOT part of a foul water system. Am I right ?
I have had several quotes from prospective installers for a new combi boiler but they all seem to have different understanding of the regulations on this.
My neighbours fence (boundary) is 1.2 m from the wall where the horizontal flue would ideally be sited. I understand that for CONDENSING boilers the minimum allowable distance is 2.5 m. Is this correct ?
If so would a 'Plume Diverter Terminal' solve the problem ??
Similarly different installers seem to have different guidelines on this as well.
Many thanks for your help (in anticipation).
You are right about discharge of condensate but an inline neutaliser can be fitted that will allow it into just rain water drainage ..
The 2.5m is not a reg yet , it is being spoke about same as only having roof flues
Condensate can be discharged into rain water drains.
2.5M is the building reg distance I believe, the gas regs is 600mm facing the boundary or 300mm adjacent to it.
Yes a plume kit would work, but in reality I don't think most people would bother at 1.2 M.
The 2.5 metre figure is not a requirement of any Regulations. However it should be taken as a recommendation to avoid the visible plume from the boiler crossing the boundary and causing a nuisance to your neighbour. A Plume Diverter Kit will also achieve this if the main terminal is closer than 2.5 metres.
