Condensation Damp/Air Brick Installation
20 Mar 2008
Tyne and Wear
Hi i own a 19th century downstairs flat and it is suffering from condensation damp/mould due to no or lack off air flow in the property.
I am looking at installing a couple of Ultrovent Core Ventilator's (core air bricks)
I just have a couple of questions
1.Which rooms would be the best to install them?
2.Would it be best to install them in the top corner of a room?
3.How many would anybody suggest installing? do you think 2 (1 at the front of the building and 1 at the rear of the building would help circulate air flow?
I already have an extractor fan fitted in the bathroom but i might upgrade that if anybody knows of a powerful one they can suggest.
Thanks in advance Steve
Air vents would typically go 300mm in from a corner and 300mm down from a ceiling.
But curing your condensation issue will not be as simple as installing two air vents and trying to create air movement. There are no preferred rooms nor preferred elevations, but normally every room should have some form of constant ventilation - but that in itself my not be the solution
You need to look at the other issues of heating and insulation and production of moisture, and not ventilation in isolation
Cheers Woody
I have had 2 companies look at the property first said there's no air movement try a new extractor fan in the bathroom and a couple of air bricks/vents the other suggested a positive pressure unit to pump air around the flat.its caused down to the current tenants living situation my 2 last set of tenants had no problems like this,i dont think they ever open windows and dry all their washing on the radiators.
if it's going to be rented, you could hide one behind the kitchen units which will take the tenants longer to find and block it.
What are the windowframes made of?
