Condensation in crawl space
14 Aug 2007
My home is built on block piers and has a 3 foot crawl space which is enclosed around the perimeter. My problem is that condensation is saturating the underside of my flooring, causing some doors to warp. What can I do?
you need air flow to remove the moisture
assuming its quite a big space i would go for 3 or 4 vents on each external wall to the void
having said that there may be different requirements america :roll: :roll:
but you definatly need airflow what ever happens
