Hi, My 1930's semi had a porch added sometime in the 70's. The walls are single brick and the porch opens straight onto the hallway (i.e no door in between). The walls seems to suffer from very bad condensation and the plaster work is soaking wet every morning. I don't think the roof is leaking, I think its more a problem with the single brick walls being so cold and the warm air from the house.
What is the best solution for this? Should I try to increase the thickness of the walls?
