condense piping
JPC
10 Aug 2004
Leicester
on the subject of condense
1 - Do you use 21.5 grey pushfit..or always white solvent weld
2 if you up it to 32 or 40mm to save on insulation is pushfit ok or do the rubber seals suffer and therefore solvent weld again?
I've always used the white overflow pipe.
I also only ever used solvent weld and compression waste tees with no problems.
I cannot see why the pushfit would cause any problems though.
White solvent weld 21.5mm
Also commression tee with reducer built in , no problems
Also not seen any problems or heard of any with larger push fit pipe
