Hi
Having to get a new boiler as our has broken (20+ years old!). The current outlet for the flue is not 300mm from the ground, so has to be raised. My question is, is we are having to extend the flue anywayon the outside of the building, does the actual point where the plipe comes out of the wall have to be 300mm from the ground if there will be extension pipe on it, to make sure the actual fumes come out much higher?
Hope this makes sense! Any help you can offer would be VERY much appreciated!
Thanks!
Thanks!
