Im guessing this may fall under the area of part P notification so may not be able to do this myself. However a guide on what can be done if I cant would still be appreciated.
We have an existing ceramic hob wired to a CCU and to a 45 amp cooker switch on a 10mm cable. This is then fused at the consumer unit as installed and signed off by an electrician.
However we now wish to add a cooker maximum draw before diversity under 13A, this can either be installed on the kitchen ring main (redundant socket in close proximity) or alterantivley wired onto the cooker radial?
At the moment its 10mm from the cooker switch to the CCU. What would the best solution be? Knowlege is power and all that, even if I'm not doing it myself I would like to know the best solution and what to expect.
