HI - I think this question has bounced around a few times, but I would like some confirmation please.
New kitchen on the way and did not realise the rating of the induction hob - silly me - alongside an electric oven.
Currently have 45A breaker in consumer unit, 10mm (I think, but at least 6mm) cable to CCU. Induction Hob (7.2 KW) and Oven (4.6 KW) will be within 2 metres of CCU (intend to use 45A CCU without 13A outlet to reduce load).
Can I run Hob and Oven from same CCU?
If you can, and I think you can if you apply diversity (hardly ever use the oven as we use separate microwave combi on another circuit - except on Pizza Night), would you run 2 tails to cooker cable outlets from the CCU (it will be tight with 10mm) or a one tail to a cooker cable outlet and feed oven and hob from there?
Hope that makes sense - thanks Darrel
