Can anybody help with my situation?
I want to insulate my solid walls, i think i have read to many articles on this and have left myself confused and frustrated.
After reading about the different ways of insulating the walls, i have decided to use thermalite basic board @ 40mm thick which will give me a thermal value of 0.80 and a energy rating of A2 according to their site.
i have read on various sites that to get an even better thermal value i should battern the wall and then place the thermaboard on the batons placed at 600 apart.
This site says:
Internal thermal boards can be fitted to the inside surface of the wall. It is particularly beneficial to line cold outside walls, especially those facing north or east. Use foil-backed plasterboard nailed to battens.
Firstly fix battens on the wall and then fix the thermal boards to the battens. This will leave a gap behind the board, which will trap a layer of still, dry air - similar to double glazing your wall.
My questions are:
1) its says use foil- backed plasterboard. And then its says fix thermal boards to batons, the thermal boards don't have a foil on the back of them. So could somebody explain this more clearly. sorry if i am being thick here.
2) It says on other sites, that i should baton, then fill with rockwool, then put of pvc protection over that and lastly fix the thermal boards, because this will stop any damp.
3) What extra thermal protection will i gain over if i use batons and thermals board as appose to just fixing thermal boards straight to the wall?
4) is it possible to fix the thermal board straight to the wall with nothing behind it only the adesieve?
5) Could somebody please give me the correct way of installing the thermal boards with the batons.
i.e Can i batons the wall & then secure the thermal boards straight to them without any pvc or rock wool etc.
Sorry for all the question but in i am really confused and need to get on with the work as my wife is expecting and i need to get all the work done before the new arrival.
Merry xmas
This site says:
My questions are:
Merry xmas
