connecting 25mm mdpe pipe to water meter.
6 Feb 2010
Blackpool
Hey how would you suggest you connect 25mm mdpe pipe to an water meter that will be situated underground. Do you use the usual meter tail connections then an mdpe connector to connect on these?
Thanks will the water meter tails be ok underground, due to them begin similar to compression fittings i.e will leak if knocked?
There are a million and one water meters with tails fitted underground using the tails supplied. What do you think?
Are you blighted with moles? Who/what else is going to knock the underground meter?
